top_prop
- 8
- 18
- Suffolk, VA
So shade_tree and I have been picking away at the frankenblazers front left wheel as it was getting hot on short trips...
I drove it to Shade_tree's house as his driveway is level and mine isn't.. He Pretty well diagnosed it as a brake issue, but we wanted to pull and repack the bearings, so we got the TM out and went to work. I've got an 86 M1009... First thing I noticed was the hub seemed loose and when we started to take it out the Oring that holds the hub locker on was there but warn and basically non existant. I'm assuming what remains is the remanant of a standard 3" o ring (its part 6 below)... can anyone confirm this? I hope the right one is ok and will serve as an example but I won't know until I tear into it.
As we were tearing it down we couldn't' figure out why the Washer Key was desinged the way it was... to make a long story short, the thing was broken and appeard to us to be snap ring, but it was just a perfect crack through where one of the hole for the pin off the inside nut goes in (#13 below)... we figured this out when it broke at another spot when we went to put it all together after cleaning and packing new grease in the bearings.... so I got a truck up on blocks blocking shade_tree's "fire-mareo" project (its half fire bird, half camareo... you should ask him about it for a laugh... but I digress...
any one got any ideas where to get a new washer key (part 13 below) TM part number 17-01-014-001? I guess I'll call the dealer tomorrow morning unless someones got a better idea.
I also need a new oring seal... number 6 below called a 'packing preformed' part number 13446. suggestions on this one wanted!
