blue302stang
- 0
- 0
- Flower Mound, Texas
I replaced the non functional water temp and oil pressure gauges in the dash with autometer gauges with a white led backlighting and it got me to thinking of a possible way to improve the lighting on the stock gauges. I found a seller on flea-bay selling pre wired leds set up for 24volt. So my question is if it is possible to drill a small hole in the back of the gauges and put the LED in there to create a around the bezel type illumination? The cover is missing over the bulb for the gauges, so instead of making some sort of cover for the bulb i figured it would be easier to try the led method
