sewerzuk
- 9
- 18
- Seaside, OR
One of the sets I picked up from Ft. Lewis was this really nice, low hour -005a, with ASK. I spent my normal few hours running through everything, changing filters, purging fuel lines, etc. She fired right up, came up to 50Hz, oil pressure came up within about 3 or 4 seconds, and I thought, "sweet! this is one great sounding machine." At the conclusion of that thought, the engine began to miss for about 2 seconds, followed by several successive knocks. I hit the off switch, but before the engine came to a stop the banging turned into and earsplitting sledgehammer-on-the-side-of-the-block sound (a neighbor came over to see if I was OK). I cranked the engine over by hand and could hear compression rapidly bleeding out the intake side of one cylinder. I can hear something hitting the side of the block in the oilpan area too...
I'm betting a valve stuck, the piston hit and bent it, which bent the connecting rod for that cylinder.![Doh! :doh: :doh:](https://www.steelsoldiers.com/images/smilies/smiley_doh.gif)
What a bummer...it would be one thing if there was already a hole in the side of the block, but it was :almost: just fine...if that one valve wouldn't have stuck there would have been no issue. Spent a lot of $$ just to end up with a pile of spare parts.
It isn't worth fixing...too much work for not enough payback. On the brighter side, it frees up a lot of spare parts for the other 5 sets I picked up. I will certainly be stripping it down, so if anybody needs a good 60Hz generator head or other MEP-004a or -005a parts I may have some in the coming months...
