blackrock
- 1
- 0
- Phoenixville,Pa
Mine has bags in the rear and a custom bed. You can go to xtreme 4x4 and watch the 3 bobbed deuce episodes.
So is this Bobbed method #4 and #5looking at useing the suspention from a M149 water trailer. It is rated at
1 1/2 tons so it should work but it does looks different than an M105
The most important "part" is SWEAT EQUITY!
I thought it was a Deuce to bob in the first place?
That sounds like a job for an ATV jack. ratchet strap some plywood to the jack and poof instant hub helper. lolThe only part of the job that I REALLY worked hard at and sweated over was getting all the measurements correct. The hardest physical work was flipping the hubs by myself, but then I'm 60 years old. Next time I would build a type of jack or cart to help lift the hubs.
oddshot
Im offering a 8" lift. All 3/8 plate with pcs of 2"ODx.25wall DOM running threw the center of 4 3/8 plates. usmctopgun on this site is the first buyer and will be doing a write up on the install very soon. Also, Hanksdeuce is interested in a kit.
The M149 trailers seem to have a heavier suspension than the M105. It should work fine.I'm looking at useing the suspention from a M149 water trailer. It is rated at
1 1/2 tons so it should work but it does looks different than an M105.![]()
Here are my trailer springs no blocks.Dont cut and weld a trailer frame to a harden steel deuce frame.http://www.steelsoldiers.com/deuce-modification-hot-rodding/44800-another-way-bob-deuce.html
This has been covered.. frame is NOT hardened steel. Weld on it if you like. Nothing special about it.
Check the TM, search this site. The frame is just steel. NOTHING SPECIAL about it.I do not think it is mild steel, I believe it's frame steel. It does weld different, but not far off. Hardened is stiff, axels ,gears, stuff like that, frame has some content of spring steel.
Also it does depend on how old, Remember the titantic? If you were to compare the steels we all have just mentioned with a metal reader, (radar looking device) you would see the content does vary. Of course, anybody got a $10k device like that?
I always give a quick, warm up preheat on any frame to lengthen the cooldown time.
Please prep properly too.
Be nice if someone made spring hangers like the front for trailer springs...
