- 2,960
- 33
- 48
- Tiro, Ohio
Was driving the M108 the other day and noticed the brakes were getting soft. Did a hard braking stop and took way too long to stop. Knew the master cylinder was not returning all the way, causing some of the issue. I had rebuilt it, but it wasn't the best to start with. The airpack also was not the best, it had pitting in the main bore when it was rebuilt.
With the higher speed of a new overdrive gear, and 20,000lbs, it was time to fix it.
First thing was to adjust the brakes. For me this has been the #1 reason for a low pedal. Brakes had already been adjusted according to the TM before, so just a quick adjustment this time. Jacked up each wheel and turned the top adjustments until the brakes dragged, then backed them off a little. Pulled the axle shafts and hubs so the tire would spin freely.
Then replaced the airpack and master cylinder. Had a brand new master, and an airpack I had rebuilt from a good core.
A good bleeding job with a pressure bleeder finished the job. I use DOT 3.
The brakes already had rebuilt wheel cylinders, good shoes, all new rubber and steel lines. Bearings and seals also had been done.
Now I have a very high pedal, with nice feel to it. Still cannot lock the brakes, I would guess due the the heavier weight. On my M35, I can lock them up, and it has the same work done to it.
I did about 4 or 5 hard stops, one with me standing as hard as I could on the brakes. Truck stopped much better, and the pedal still felt good afterwards. It will throw you against the dash.
Feel much better about driving the truck now, since I'm going to be taking it on some long trips.
Dennis
Dennis
