oil cap flying off
21
las vegas
anyone have their oil cap fly off and hit the hood with a lond bang followed by plumes of smoke? is this normal operation? what causes this? how do you prevent? the engine still runs and engine temp was never over 190. oil was full and needed only about 4 quarts of coolant. thanks for any help.
Carl_in_NH
Wilton NH
Eh, no - it's not normal for parts to depart all by themselves. If the cap just popped off, that would be one thing - but to hit the hood and make a loud 'bang' requires some serious pressure to build up.
It's either as S&C suggests with the breather plugged, or possibly a blown head gasket causing pressure to build in the crankcase faster than it can dissapate through a restricted vent - but I suspect you'd know something was wrong by how poorly it was running or the strange noises it was making.
Pressure like that should never build up in the crankcase.
How's your oil look? Any coolant in it? How about the coolant? Any oil in there?
21
las vegas
but isent normal oil pressure higher then coolant pressure? so if it was a blown gasket would coolant have the pressure to blow off the oil cap? it smelled like oil not buring oil, more like exhaust and no coolant smell either. could this be caused by overheating and a clogged coolant system? :???:
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Could be valves need adjusting too. I don't know how much pressure there should be, but to shoot the oil fill cap out, that sounds like something is wrong.
Ord22
Stockbridge, Ga
a blown headgasket won't make a cap come off, never heard of that. check your breather tube. check to see if your cap was on tight, a big maybe?? if you had a blown headgasket, you will have compression in the coolant system and loosing coolant. check your coolant and oil levels.
21
las vegas
the cap was on tight that when it came off it hit the hood so hard it sounded like i blew a rod. i will post picks of the dents on the cap from the hood and the oil splat on the hood. like i said engine still runs fine and starts right up. :lost:
fstfrdy
crosby,nd
maybe a dumb question but what motor are we talking about. if its the cummins i have seen this on my fathers road truck(400 big cam) the cap would simply come off cause the rubber that you squish to seal it in the cover would become soft from wear and soaked with oil and the extra pressure from high rpms would pop it out.
rosco
Delta Junction, Alaska
I have seen gasser's ignite fumes in the crankcase, usually, when you are trying to start them, but other times as well. The engine was tired and there was oil dilution w/gas, due to blow by. They blew the valve cover gasket out from under the valve cover.
Are you getting fuel in the crank case? That "pre-heater, cold starting valve", leaking some? We're you lugging the engine, at the time it blew? You should not have smoke in the crankcase, not much anyway. That suggests to me, some internal combustion.
gimpyrobb
27,785
748
Cincy Ohio
Probably not a cummins, this is the deuce forum.
