PTO seal replacement
M35A2-AZ
392
Tonopah, AZ
My pto was leaking a little at the seals so I pulled the pto and replaced the seals. I took some pics to help others with there seal replacement.
It was not to hard to do, the nuts that hold the pto to the trans can be a pain.
I used a two lip seal for the shift shaft (National #471538.
You do have to use a gasket to set the back lash when you put the pto back on the trans. , but you can not use a Dial Indicator (like the TM says) with the PTO & trans in the truck. So I just used the same thickness gasket as I took off. I did move the gear and checked that it was not to tight.
I noticed I had chipped tooth.:mad:
m16ty
218
Dickson,TN
You're right about the dial indicator. No way to get it between the frame and the PTO.
You may want to try your edit again. I'm still seeing :cool:.
