Napoleon_Tanerite
- 3
- 0
- Warner Robins GA
I suspect that my injector pump is on its last legs. Here's what I have experienced:
--An overall lack of power (I know the 6.2 is a dog, but we're talking unable to accelerate from 35-40 on a reasonable hill)
--Poor fuel mileage (~12mpg)
--Hard starts when cold (cold is a relative term in August in GA, I mean the first start of the day is usually an affair. The truck will start, idle for a few seconds, sputter and die if not revved up, then require ~10 seconds of cranking before re-firing)
--Noticeable black smoke in exhaust with no load, significant black smoke when under load (such as towing)
--Noisy (I have insulated the cab with two layers of FatMat, rubber floor mat, carped, and a hood blanket, windows rolled up, air conditioner on, and it's STILL louder than a friend's bare bones M1009 with windows down cruising along with my feet burning on the metal floor)
I've changed the fuel filter, run several tanks through it treated with Diesel Kleen, changed the air filter, changed the oil, run it hard, all the tricks I know of to clean anything out of the system with no improvement. I'm left pointing at the IP through process of elimination. What else should I look at before taking it to the shop?
