Hooper
- 0
- 0
- Grand Rapids
I found a few of these and wonder if anyone knew if they would work on an A3 rim?
Work or right. I know the work on the stock wheels but do not fit right. They are smaller than the A3 tires also .
They will work fine for the rim design. As stated, they will cut your top speed because they are the height of 900s VS. the 14.50 which are the same height as an 1100.
Thanks Gerhard. I believe that you and James (M1075) are reponsible for much of the inspiration for it - as a result of various tire/wheel discussions over the years here.I like that combo!
G.
I will be adding this combo to the front of my M342A2 and M108A2 also.
The A3 wheels are designed for tire marked MPT. 14.5R 20 Michelin's are this and another example is the 12.5R 20 Continental MPT's. I have a set of the Conti's on A3 wheels on the front of my crane truck for a better footprint and higher weight capacity over the 900x20 NDT's.
Thanks gimp.Might be able to bring them back from Ga rally Crusher.
