Brad M
- 0
- 0
- Belmont NC
I read up on this here on SS, used the TM/34 for info, and replaced a worn front output seal on my M1008 transfer case yesterday after work. I checked the bearing play and there was little to none on the front output shaft. I lubed the inside of the seal, applied a small amount of silicone to the outside diameter of the seal, and gently put it in until it was seated flush. I cleaned the surface of the yoke that the seal rides on then lubricated it. I replaced the yoke and tightened the nut to 120lbs Then I bolted back up the CV/propeller shaft and refilled the fluid and had another leak from the inside diameter of the seal where it touches the yoke. Can anyone give me an idea of what i may be missing or not thinking of that could have caused this seal leak. I have one more seal and will check what failed when pulling it back apart but I am at a loss. Any suggestions or what to look for are greatly appreciated. One I have already heard was to pack the spring side of the seal with grease incase the spring slipped off when the yoke slid in place.
