tire dolly
bones1
Southern Maryland
Has anyone here ever made a tire dolly for pulling dual wheel assemblies?. If so please put up some pics or even ideas on what you would build.
AceHigh
31
Lake City FL
Yeah. Another use for it would be rolling the M35A3 wheels around till it matches the air inlet. I know some guys use a pallet jack.
RAYZER
59
sanford/florida
I have used a 3'x3' peice of 3/4" plywood with 4 or 5 pieces of 1/2" sced 40 pvc pipe underneath for rollers,this contraption will roll the duel wheel set off and back on with ease!
I think this idea has been around for thousands of years,if the egyptians had military trucks,this is how they would have moved their wheel sets around!:mrgreen:
John S-B
1,135
Ostrander, Ohio
I like your idea best, I've been doing some brain storming myself for when I have to my bearings. My deuce is parked on gravel so I will have to have two pieces of plywood. I just need to get a sheet of plywood, I've got the pipe. (I'm going to use 3/4" conduit as it's thinner so I don't have to raise the axle as much) I can easily rig up some 4x4's to the plywood to keep the tire from falling over.
So for the price of a sheet of plywood I have my tire dolly, THANKS!! [thumbzup]
TIGERFANS2
Topeka, Ks
Used this method a couple of days ago, slicker that goose poop.
Home Depot:
2'X4' 3/4" plywood
several pieces of 1/2" sched. 40 already cut to 2' long @ $0.97 each (or find a piece or two of STRAIGHT 10' sched. 40........and make your own)
ran mine fore and aft, (the 4' length that is) so the wheels could be chocked on the board and then positioned easier when re-installing.
nopics
and I didn't think to take any whilst doing the job....sigh...
tco3129
Flat Top W.V.
I just grease a piece of scrap plywood, slide them off and roll out of the way. Reassembly is reversed.
A little messy but you're gonna get greasy dirty anyhow.2cents
3dAngus
102
Perry, Ga.
I can see how a pallet jack would work well.
Shipping is just to much on these, but I will be having four of the professional dual wheel dollies at the Ga Rally. Normally about $650 new, for $95 used. They will align up the holes and studs perfectly with ease when putting them back on. Just thought I'd mention it, in case anyone goes and is interested.
big block 88
Topeka/Kansas
We found one at the DRMO in Ft. Riley it works great it has rollers where the tires rest so you can rotate them. Problem is we lent it out and it never made it back to the shop. I guess the guy thought he needed it more than us
