warteetee
- 0
- 0
- Pennsylvania
I have a MEP-017a 5kw gas generator that I just can't seem to get to run. I can rire it up with some motivation fluid (ether) but it will only run for about 5 seconds and then it shuts down right away. it doesn't matter if I keep squirting fluid or not, it just stops. I can then wait a few seconds and fire her right back up and then again, 3-5 seconds later it just shuts right off again.
I have the 5kw deisel generator as well it it too would shut of after a couple seconds and I narrowed it down to low oil shut off. I have checked the oil in the MEP-017a and it is right where it should be - could the sensor be bad and it is shutting it down?
I have replaced the fuel line and checked the fuel pump and I am getting fuel to the carb.
I am stumpped
at this point and was hoping the wisom here might have some ideas.
I have checked the old posts related to the MEP-017a's and was not able to find anything to help correct the issue I am having.
Thanks
I am stumpped
![Banging Head aua aua](https://www.steelsoldiers.com/images/smilies/icon_smile_banghead_125.gif)
Thanks
