Floridianson
- 2,503
- Interlachen Fl.
I did a search. Someone had a thread where they found the bracketts and the bar with the corect offset that will fit my 818 from NAPA. Thanks
Im also looking for a set to install on my deuce road tractor.I did a search. Someone had a thread where they found the bracketts and the bar with the corect offset that will fit my 818 from NAPA. Thanks
Thanks. The center reciever bar is attached to the truck by a reciever on each side, that is just so it can be removed, and I can use the pintle hitch, so no it does not have a 3 pt hitch.4x4e350 the flaps look good and I like the receiver set up. Are you running a three point hitch too?
I just use LED tail lights, they can be used for both 12 and 24 volts, for the side markers I just replace the 12 v bulbs with 24 v bulbs I got from Bulbsdirect for 88 cents a piece. I just ordered a Tekonsha P3 brake controller, I am going to hook up through the 12 v converter I already have in the truck.Real nice setup 4x4.What do you use for civy trailer wiring?
