GL now show video to dump M101
doghead
4 Star General /Moderator
1,193
The auction is over, right?
swbradley1
Modertator
1,939
Dayton, OH
I had heard that they dump but this was the first time I had actually seen it in action.
thx
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
That video is not complete. You should also add a flex hose to your brake line so it doesn't crack and removing a wire harness anchor would be a good idea too. Wonder how long it takes till they get sued for advertising a "non-feature".
73m819
329
gainesville, ga.
seems like a production, also looked like when the trailer came down, the leads got pinched between the frame and the bed.
319
Lieutenant
3,347
58
Michigan
I believe that if the 101s truly had a "dump feature", you wouldn't have to remove screws and disconnect wires, add flex lines to the brakes, or remove bolts. The wire harness would be coiled, as in the case of the telescoping convoy lights on trucks, the brakes would already have flex lines, and hitch type pins instead of bolts and nuts. And something to limit the travel of the bed.
3dAngus
102
Perry, Ga.
It was designed to tilt. Even so, precautions need be taken. The video is on the right track, IMHO.
I would not put a full load on this trailer and try to tilt or dump it. They show it empty in tilt mode, and call it dump.
I don't see any need to dump on them for it. I find it educational. It pretty much so is a graphical representation of what has been said many times on this forum, but a picture is worth a thousand words.
KsM715
142
St George Ks
No, it wasn't designed that way. It was designed to have the tongue unbolted from under the box ( at the bolt near the spring pack) to facilitate in packing the trailers in tighter for shipping purposes.
Edit: http://www.steelsoldiers.com/859791-post41.html found in this thread on page 5 : http://www.steelsoldiers.com/trailers/70462-m101a2-not-dumping.html
(found searching M101+folded)
3dAngus
102
Perry, Ga.
KsM715, that's what tilt means. Dump is entirely different.
It was NOT designed to carry a load and dump it. It was designed to tilt for packing them in a plane or ship for transport.
The Chief put up some nice pictures a while back of them stowed in the tilt position where they just packed a ton of them in there for shipping. I forgot what thread it was, but it was an interesting and educational read.
820jeep
Fort Worth Texas
I just won a M101 at Ft. Sam Houston, San Antonio Texas, No EUC required. This makes my 4th 101, but all the others had to have a EUC. What up?
