Say Jonathan, Kinda curious to know what you thought of the "Beartooth Highway" from Red Lodge to Cody and the other areas you visited there. Was the trip "UP THERE" worth it? I kinda thought that maybe it would be at least one of the highlights of your "Epic Journey and Separation"! It sounds like you had a fairly good trip despite the flats and your brother having problems. Glad it turned out ok for him though. Take care and keep in touch. Call me sometime if you get a chance. Good luck!!! Walt aka elkmhunter
It was absolutely fantastic. We got to the top of beartooth just as the sun was setting. I cant even find words to describe it. We got within 5 feet of some mountain goats, and tried out the oxygen lacking air... breath taking! The ascend was rough, mostly 20mph and below in low gear. The decent was the same, but done in the dark.
It was very worth it. Had I gone alone, I probably would have stayed there for the day just admiring the beauty of it. I couldn't imagine a more perfect place to be, I was on top of the world.
The trip ended at 4am here in Oklahoma. After the military vehicle museum we drove straight through the rest of Nebraska, Kansas and into Oklahoma. The museum had to have been the coolest place we went to. We got there an hour before it closed, but they kept it open for us. I ended up buying hats, posters, patches and a grenade.
Met a really cute girl that worked at a coffee shop in Keystone, just before Mt. Rushmore. She was headed to Seattle for school. This was the closest any of us got to female contact the whole trip... minus the two larger women that drove up to the deuce and tried to flirt with us. I treated them like the bison we saw everywhere... didn't feed them and drove around them in fear of being attacked.
Had another tire failure today, one of the inner rear duals decided it didnt want about a 10"x4" patch of its tread. Now I am looking for some tires!
Total weight for the trip was 22109 lbs.
avg mpg was 7.20
best mpg was 8.974
worst mpg was 6.7
Right rear outer hub is now dripping a hefty amount of fluid
The transfer-case air line decided to unscrew itself partially and sprayed lube everywhere. Easy fix though.
The head gaskets are leaking oil like mad.
The front wheel boots are shredded.
The rear main seal looks to be leaking.
The EGT probe popped out and made an interesting sound. Easy fix though.
Got pulled over twice.
Saw tons of field mice, prairie dogs, deer, elk, bison, cows, horses, skunks, raccoons, and few other splattered wild life.
had one negative comment about the truck, and probably a thousand thumbs up and waving.
