M38/GPW wannabe!
tigger
Medic.
50
Butler TN.
Well thanks with some help from OnegmJack ( dwight) The jeep came back to life after setting for 6 years. Have a few leaks to fix got the new fuel pump on today and adressed some of the leaks. Got the dash in . Ill post some photos later im on a friends computer, i have to leave to go back on the road in a few hours.
tigger
Medic.
50
Butler TN.
Some idiot (me) broke the bolt off to mount the new distributor. after a lot of adult words and 3 broken drill bits and 1 broken easy out. was able to chase the threads and get the new dist. installed. got the dash in too. Not as much Adult words doing that. lol
tigger
Medic.
50
Butler TN.
PB you wouldn't have a 16 in rim in usable condition laying around? my rim for my spair is pretty bad. don't have to be pretty. just not ready to rust in two.
2,419
Sorry Tigger...that's one thing we do not have extra of. We looked when Zout needed some.:sad::sad:
jamesfrom180
71
Gainesville/Florida
I have a generator and rectifier that I pulled off of my old M38a1. I'm not sure but I believe it was putting out 12-14 V. The jeep had been converted over. If you wanted to replace that alt.
tigger
Medic.
50
Butler TN.
Well the body is all together, lights hooked up and working. Drove it arouind the yard a little. Have some picks but im on a friends computer. will post the photos monday when im back to work.
onegmjack
Kingsport TN
Sorry I could not make it this weekend.Glad you have your Jeep up and running.Call when you come in before the Rally.The Walmart, Exit 34 sound like the place to meet. I still don't have a good computer,but will soon. I am going to bring my son's Verizon 5spot to the Rally if he will let me borrow it.
tigger
Medic.
50
Butler TN.
Well a nother cold day put a crimp on my painting. but i got a lot done. none of my help showed up. The windshild frame is worse than i thought. so i hit it with the wire wheel and painted it. will take it back off after the rally and do a better job with it. im just running out of time. Have to get back to work tomarow. Still have to redo the seats and spray the inside of the tub with bed coating. and bolt the roll bar down. and change some tires. Pvt bones was trying to help but he was dead tired. Pvt Bones will be comming to the rally. The jeep will not be compleatly done for the rally but its comming. the things that count work . Engine, brakes, lights all work! so when you see it just under stand it is a work in progress!
