rjinga
- 1
- 0
- Monroe, GA
Has anyone ever seen, or used, spray can bedliner on a CUCV bumper/grill guard? I saw it uses on the after-market bumpers of a later model Blazer on a 4x4 TV show, and it looked interesting.
Linex for the interior floor and bed is on my wish list.You can always line the whole truck..., but it is really expensive.
yes that is in the plans. just tape the holes so it does not get in and cause problems putting in the pins. here is a set i did for one of my other trucks. it isnot a close up though. i also taped the pins and just sprayed the ends so it would match and still go in the hole.Would/did you spray the D rings too?
ive heard of people doing plastidip or plasticoat, or somethin like that. i have never used the stuff so idk. i think the only problem you might have using herc or whatever on a wheel would be getting an even enough coat as not to affect balance. but at the same time, on larger tires it doesnt really matter. go for itCould this stuff (hurcliner) be used in the wheel well as sound deadener?
I had the rockers and lower facica on my 01 Dodge done about two years ago. Looks good and is holding up well. Linex, @ about 650.00. Anyone spray the body with bedliner? how well doe
s that work?
