Deuce007
- 0
- 0
- North Dakota
I got an M35A3 the other day and right away noticed that the all of the tires on one side are on backwards. Is there a reason for this?
Tire direction won't always prevent you from finding out which way a vehicle was going, you can tell by the way the dirt or sand has been thrown.Bing Bing, Derrick gets the gold star. At one time it was a tactical issue, but later it became obvious that the tires were just put on the way the were mounted.
Dirt
No, they would still be one side forward and one side back. If they ALL where the same way on the flooor then, no matter how much you swap, you would still end up in the same configuration.If they were all laying the same way on the floor after being put on the wheel, then one side would be forward and one side backward. Change them side to side and you'll have them the correct way.
Oh, and a tractor company told me that you'll see some of the big combines with the drive tires on the wrong direction for going forward...so they'll clean and work better backing out of mud they drive into.
