Show Me Your Tractors (M818 for example)
Whats your tractor
  • M275A2
    Votes: 6 8.0%
  • M246A2
    Votes: 0 0.0%
  • M52 M52A1 M52A2
    Votes: 8 10.7%
  • M818
    Votes: 51 68.0%
  • M931 / M932
    Votes: 4 5.3%
  • M983 W/ CRANE WO/CRANE
    Votes: 0 0.0%
  • M920
    Votes: 6 8.0%
  • M746
    Votes: 0 0.0%
  • M911
    Votes: 1 1.3%
  • OTHER
    Votes: 15 20.0%
doghead
4 Star General /Moderator
1,174
My M818
Thanks to the SS guys in Michigan.:beer:
Robo McDuff
In memorial Ron - 73M819
1,490
Czech Republic
Please adjust the pole to include an original and unique M512-A2
it is now a street-legal dump truck (M51) annex tractor (M52) :driver:
73m819
319
gainesville, ga.
you have a 246 listed, why no 819, these two are you self-load tractors, long before the k-boom trucks
indy4x4fab
Banned
1,711
41
indy, indiana
the m246 will be coming off and a place for the m915 will be added. the main reason i did not add the 819 to the list is that even tho it is a tractor its listed as a wrecker tractor, the wrecker over rules the tractor and because it can be used as a wrecker in a recovery role, which in turn places in the "Wrecker Count'' post.
73m819
319
gainesville, ga.
the 246/819 TRACTOR, WRECKER (not a wrecker tractor) were designed as a tractor to pull a recovey trailers AND as a wrecker to recover what ever is to be loaded/hauled on the trailer, a true DUEL purpose MV, so yes thay would fall into both catagories , a tractor, a wrecker,
In vietnam, more then once our 246 pulled a long neck lacross lowbed with no recovery involved, it was the fifth wheel that was needed
indy4x4fab
Banned
1,711
41
indy, indiana
the 246/819 TRACTOR, WRECKER were designed as a tractor to pull a recovey trailers AND as a wrecker to recover what ever is to be loaded/hauled on the trailer, a true DUEL purpose MV, so yes thay would fall into both catagories , a tractor, a wrecker,
OK TRUE, but I only have 10 lines to work with here.
indy4x4fab
Banned
1,711
41
indy, indiana
Can I get a Moderator to help clean this little mess up a bit. Grouping of same basic chassis on the same line will be fine.
Some times Ron you can be a bit of a pain in the butt, but you are one of the smartest TM guys I know, so to you I say, ok im not going to win this one. Would you mind laying it out in in ten lines how you think the pole should read.
