91W350
- 60
- 48
- Salina, Kansas
I use a 1/4 inch drive deep six point socket to break the bleeder screw loose and tighten them with the same. Finger tight will shut down the fluid/air exchange. G
Add a pressure gauge to your bleeder. Then you just pump up to 15psi and crack the bleeders.Maybe I need a little more pressure in the sprayer tank as well, I was never getting more than a very slow seep. No gauge on it, just gave it 30-40 pumps.
Bled them this morning and while it's not 100%, it sure went a lot better than last time! The pedal stops before hitting the floor, but it's not quite as firm as it used to be. I'll do it again before I take her on the road.
The fluid that came out was noticeably cloudier than the new stuff. So it's probably a good thing to flush more of it out anyway.
Reading the TM on pedal adjustment, it says the pedal should have .25-.5" of movement before free play is gone. Mine goes almost to the floor pan. I don't think it's a pedal issue. I'd better bleed again first, this time on concrete instead of grass, and with practice it'll go better.I would highly reccomend adjusting the brakes and the adjust the play on the brake pedal.
