466Navastar
- 0
- 16
- Buffalo,ny
seems like this would be the Ultimate wrecker
A wrecker puts a totally DIFFERENT loading on a truck frame then a trailerthank you 73M819....im not copying your transmission - could you please LONGHAND what you mean? - cause i was thinking the M920 is a 75,000 gvw truck
you said- "also is the 920 frame double,triple, and spring lockouts would be needed for the rear suspension so it take the working load when not on out riggers ".........WHAT?
Your comparison regarding "pulling or haulin" is well noted, but that is what not what 73M819 mentions. If you read the thread again, you might learn something from the 4 Star.i dont beleave what i just read i have a m920 an it will out do any 5 ton any day of the week pulling or haulin an if you have a 5 ton an want to lose some money bring it on .an it has a double frame an full lockers - detroit an they do not hop around like a 5 ton . a m920 is built to handle 20tons up down or side ways .
The crane while very useful puts a totaly different and a lot less stress on the truck then a wrecker doesI am pretty sure my truck is the only crane on a 920 you will find, I think it is safe to say that with the relatively "new" nature of this truck that it most likely has not been done yet. Links below show the build.
Without question...That is the ultimate 'wheeled' recovery vehicle!Here are the pictures that I promised.
