Westech
CPL
- 6,104
- 208
- 63
- cow farts, Wisconsin
I got two sets for 2 bucks....... Swap meet.
Ok, sorry westech. I am a little new to this and couldn't figure it out even after I read the whole, entire thread. But, I appreciate the help the following poster provided.I am guessing this dude did NOT read any of the post.. just seen the name and posted a question. By the time it took to type his question he could have look at the post and figured it out.
Same stuff different day......
rub it in! lol...if we had swapmeets around here that i knew of i would go... still 18 bucks was still WAY less then i thought id ever pay for a complete gasket set for anything...ever! lolI got two sets for 2 bucks....... Swap meet.
I quit using those paper gaskets long ago! Now days I use paint because it works much better. I brush on a nice thick of coat of enamel on both faces, and let it dry. Then I bolt it back together. I have never had a leak afterwards.
I even use paint on the threads of my bolts as a thread locker.
Is preload something like heel, and toe on a ring, and pinion?The problem with that is on the trans the gaskets are used to set preload and proper distance between parts.... RTV or "Paint" will not hold the correct size and presto... Junk.
