SMOKEWAGON66
- 21
- 0
- California
Ok so ive searched several different ways and different keywords and havent had much luck so ill go ahead and ask.
Drove the truck this afternoon and drove it enough to get the engine good and warmed up, and when i got back i did some after operating checks and noticed that the top of the radiator was hot, warm in the middle, and ice cold at the bottom. I opened the draincock at the bottom and the coolant that came out was very cold....
in my best guesses, the fluid coming out at the bottom of the radiator should have been too hot to touch. So i squeezed the bottom hose and could hear fluid rushing through the radiator. It seems that the radiator is working but im wondering why its cold on the bottom. Which way does the water pump move the coolant? does it go top down or bottom up? Could the thermostat be stuck shut?
any ideas? Suggestions? i wanna drain the system and pull out the trhermostat, clean everything out and check the sending unit to see if it works..Any help would be greatly appreciated.
