Nicholas
- 2
- 0
- SE South Dakota
I just bought an M818 and drove it 200 miles home. On the way home the pinion seals started to leak. Can I remove the bearing retainer put a new seal in and then reinstall with out doing the preload? Or is it possible to remove the seal without taking the bearing retainer off?
The next issue is with the transfercase input bearing. It is very loose, is it possible to pull the bearing out with the transfercase in the truck?
Thanks for all the help.
Nick
Nick
