Awesome Possum
- 0
- 0
- Central Texas
Texas heat has finally broken and me and Badga have gotten a HUGE amount of work done (at least for us) in the last two days, but now we need a bit of SS knowledge. Just found out I have Badga for an extra day tomorrow so have to throw a work schedule together real quick.
We have the deuce front springs placed for the rear axle, and the mounting holes on the sides drilled and bolted on. Tomorrow we need to drill the holes for the bottom of the mounts. The problem is removing the leafs from the mounts in order to drill these holes. Looks simple enough, but this is usually when I get in trouble.
I hope the stuff I added to the included pic can be seen. I figure A & B ( retaining bolts) can be removed, and then C is driven out towards the center of the truck (in the direction of the blue arrow). I'd use a socket to protect the zerk fitting when tapping it out. The other end of "C" has a slot in it as if it was for a big screwdriver. Do I need to know anything here?
I've seen the mounts bolted to the frame both with and without washers. What's the verdict? How about lock washers? All will be grade 8.
Thanks
Thanks
