- 6,923
- 2,373
- Montevideo/Uruguay
Just reinstall spindles and hubs but leave both complete axle shafts out.I think you've hit the nail on the head. I'm making the drive tonight (200 miles) back to the truck to try to get her home so I can fix things properly.
My question... If it's the spider, what do I have to do to make it safe to drive back? Remove forward driveshaft? Remove axle shafts? Obviously the less I have to do out in the bush the better but I will do whatever is necessary.
Thanks again.
Or make that trip with both drive flanges removed.
You don't have to disconnect the propeller shaft if you have the Air-shift TC.
G.
