Extended Steering Arms
MrM4
21
Wall, South Dakota
Does anyone here build custom steering arms for dueces with a lift kit? My M35a2 has a 9 inch lift and was wondering if anyone would consider building me a custom arm? I have a custom shop who is about 90 miles away that thinks they can do it but they would like for me to trailer the truck to them to look at while fabing the arm, Id rather not haul it all that way if I dont have to.
Anyone have experance with what to use or what not to use? And how think of metal you should use?
HanksDeuce
242
Prairieville, LA
Contact member blackrock on here. His name is Kyle. He'll make them for you no matter what lift height you have. He is making me an 8" lift kit with both steering arms extended.
MrM4
21
Wall, South Dakota
I can't help but think of the ADDED stress on the 4 mounting bolts caused by the leverage of added length
Im sure the extra length does create more stress on the bolts but I have never heard of them failing. I made a temp steering arm out of 4inch wide 3/8 A36 steel to move the truck in and out of my shop, I managed to bend it because I turn the wheels without them rotating and that was with just 9.00-20s. After alittle fixing it works fine as long as the tires are rolling when you turn.
All I need now is the steering arms and to cut my wheel centers and mount up the 16.00- 20 and I can take her for alittle ride finally.
A sneak peak of the work in progress with my new tires sitting in place unmounted, snaped with my camera phone.
khandoh
Warner Robin, GA
I hate to sound this way, but I wonder how hard a good solid redesign of the part as a whole would be? I am not saying that lifts should be abandoned.... But the arm was bent by a stationary tyre? Slow speed OK. but trying to change the direction of a 500 lb gyro?
MrM4
21
Wall, South Dakota
The arm that bent was not the orginal arm, it was a basically a small part to allow me roll the truck around my yard so it wasnt in the way, theres no way I would drive it on the road with a light duty part made out of scrap I had around the shop.
