That's what I do in the Unimog U1300 and 404 Radio truck. Some converters can be connected directly to the battery but most can't. Two reasons: the current from the battery will flow backwards into the converter when the converter is off, and second, if there is a direct connection to a dead battery, a dead battery can cause a tremendous load on the converter when it is turned on. It may or may not be able to protect itself. I fried several Samlex converters until I 'learned'.
For the reverse flow current, the converter will most likely survive but the battery will be discharged. A diode in series, conducting toward the battery, will prevent reverse flow. A small resistance, even half to one Ohm, will prevent too high a load to a dead battery (12 v into 1 Ohm provides 12 amp flow limit). Size your resistor according to the converter rating (and include wire resistance)
Adding the diode compounds the need to turn up the converter voltage. Add another 0.6 volts for the diode junction drop.
I use Wilmore converters of a model that do not discharge the battery, and have good self protection for over-current. I float the 12v battery at 13.8 vdc (voltage recommended for most ham transceivers, and float v for many batteries) and that works great for normal usage, but I do connect a real charger to the 12v battery every few months to provide a cell-equalizing charge. (The truck batteries get an equalizing charge at the same time.)
Bob
What if I want to charge a 12v car battery with a convertor so I can run my 12v stiff off of a different battery? Do I need to have a some kinda battery charging electronics between the convertor and the battery, or can I just hook the 12v side of the convertor straight to the battery?
