The wheel cylinders are all the same, 1-3/8" bore. IIRC, NAPA carries them although I don't know a part number. Would like to know since I have another two wheels to service tomorrow and have only one Star-branded overhaul kit.
Since these use DOT 5, there is almost NEVER any corrosion. And it takes 30 seconds with a hone to make them LIKE NEW. Parts pop in, just wet with DOT 5, then assemble. Bolt in, leaving the bleeder open for gravity bleed as you are packing the bearings.
Alternate/OEM Part Number(s): 111624R91, 3004802, 393321C91, 5461612, 592258C91, 66964, 681093, 827223, WCK13644
Possibly NAPA UP-176
