- 2,705
- 754
- Oakwood, Ga
My understanding is that the safe "engine" speed for the M1008 is lower than M1009 and lets assume all stock rear end, tire size etc. Given that both vehicles share the same 6.2 and transmission I am assuming the difference is the rear end gear on the M1008 turning the 6.2 at a higher rpm at the same speed as the M1009.
Assumptions: Stock Equipment
Questions:
1.) Is rear end gear different between the M1009 and M1008?
2.) Is the standard tire size different?
3.) What would M1009 owners consider a top "safe" speed.
4.) What is max RPM for sustained running that you should be driving at.
I see alot of discussions on top speed and rpms talked about on the M1008 but not as much on the M1009.
I really need to hook up a tiny tach![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Questions:
