- 2,186
- 86
- 48
- Zimmerman MN
They both were were off when i got done changing all dogbones. The whole right side was about a inch and a half lower than the left side.You guys are a riot!
So, you mentioned that you measured fender clearance, but now are talking about the dual setup in the rear. Are you wondering about the rear or the front? My pass side spring pack sags more than the driver. Pretty easy to measure that between the bump stop and the frame.
Are you worried about the front or rear?
I noticed after driving it (there were suggestions that driving it after suspension work would straighten the issue out) there is an issue with my middle axle now.
After driving it the middle axle is not parallel with the rear axle, is that normal for it to be noticeable? I know there's lots of room for pivoting and flexing but it doesn't look right to me. How straight should the axles be in a line? Is it normal to notice one axle out of line? I can post a pic if that would help.
