hemichallenger
- 2
- 0
- deland fl
I have a lds that we have flowed the injectors and turned up the pump and can not get the stock clutch to not slip. I have had it out and replaced everything with new, turned the flywheel had it back out and can not get the clutch to stop slipping in the top 2 gears under hard axcelaration. I can turn the fuel back and it is ok or with the 900x20s it will not slip. With the 395s I have the problem. So I think I need a stronger clutch. So I am looking for something that is stronger and will take more torque.
