cucv no power to starter relay
aspen2hhi
waukegan, IL.
HI Yesterday I was cutting dass in my m1009 for radio install all the sudden starter started cranking and wires started smoking pulled the battery cables removed starter relay put cables back on no smoke did the doghead relay mod truck fired up everything worked except voltage gauge. all good. today went to install radio the metal case slid through and sparks from the top of relay went to start truck starter wont turn. I tried jumping the rad and purple wire with screw driver nothing got out electrical tester no light on either red or purple. is there a fuse or fuseable before the starter relay
help please
doghead
4 Star General /Moderator
1,193
Look at the link posted above, in the second picture(starter circuit), above the word Suppressor, there is a red "thermo wire". Thats the fusible link that supplies the starter relay power. You probably blew that. It is under the hood, on the passenger side connected to the buss bar.
wrong schematic, there SS
mistaken1
Kansas City, KS
The number one rule when installing electrical gizmos (or doing any electrical work) is to remove the negative wires from both batteries. That prevents the electrical fireworks from appearing right before things stop working.
doghead
1,193
Warthog
245
OKC, OK
To clear up a question from Doghead, on the Starter Relay hot feed wire, the wire to the relay is 3 RED-2Y and the fusible link protecting it is 1 RED-2Z
Using the cheatsheet from the first couple of pages of the Troubleshooting section of the TM 9-2320-289-20 or TM 9-2320-289-34 technical manuals,
the sizes and types of the wires are:
3 RED-2Y (SXL) is a 12 gauge Heavy-walled, high abrasion, cross-link polyethylene
1 RED-2Z (Thermo HW) is a 16 gauge fusible link, heavy-walled, silicone over cross-link polyethylene
So you will need a a 16 gauge fusible link wire.
And for future reference, the wire size of a fusible link is molded into the black plastic barrel connector. In this case you should see a "16" on the flat surface.
Hope this clears up some confusion
doghead
1,193
Thank you Warthog, for the correction. I was looking at the fusible link and thinking that was the wire number, then adding 4 to that gauge number, and came up with 20ga(incorrect).
I should have followed the wires complete path, and I would have seen the correct number for the wire. Then I would have realized the fusible link info was right there and did not need to add 4 gauge sizes to it(oops).
I appreciate your prompt reply.
Sorry for the confusion.
Recovry4x4
LLM/Member 785
1,827
GA Mountains
Is your radio tray still laying on top of the start relay under the dash? Wasn't that the source of the recent issue?
mistaken1
Kansas City, KS
12V (or more) of DC acts like a welder. Did you check the circuits you repaired to make sure they are not grounded (or open) somewhere else along the path?
IOW you could have melted some metal onto a terminal that is now more or less fused into a dead short.
aspen2hhi
waukegan, IL.
so I replaced the link and when i hooked up the battery it started to smoke I have looked for areas where the wires look messed up and cant find anything wrong anyone have a clue where to start
doghead
1,193
Have you looked at your relay? is anything touching it?
You could disconnect the wire at the relay, then connect your batteries and see if you still have a short.
doghead
1,193
Better look over that wire, from the buss bar all the way to the relay.
Warthog
245
OKC, OK
Try disconnecting the "new" relay and see if you still have smoke when hooking up the batteries.
