- 10,884
- 820
- Appomattox, VA
Buy it, save it and give it a good home. Even if you don't want it yourself, I'm sure you can find a home for the parts on SS....
MattM376x6, thanks for all the info! I am a little overwhelmed by all the good-will and great info here. Thanks to all!
As I said, I plan to be at the scrapyard at 8:00 tomorrow morning. I will not have time to work on the thing much for a year or more, but my hope is to run and use it..it will have to compete for my favor with my faithful 1954 IHC 1-ton.
Good luck (I'm jelious) let me know if I can be of asistance to you in your project!
That driveshaft set-up is wild, I would not expect long life from the u-joints either side of the carrier on the front-rear-axle, if you drive over uneven terrain,.
It was the same (type) set up used on the CCKW 2.5 ton 6X6s of the period.
Ah, the dilemma of keeping it original! I definitely will NOT throw a small-block V8 in it and Chevelle suspension. But I want to run it, so if a suitable Diesel engine comes along, like a 5.9 Cummins, or even a Nissan SD33, or Isuzu 4BD, it will be hard to resist the added safety and fuel economy of Rudolph's engine. Carb is already gone form the flathead 6, and I do not know how long it has been raining into the intake.
My WC51 came with a small block V8 that a PO had installed. When I restored that truck, I pulled out the V8 and installed a T223 6 cyl. flat head. The engine compartment is kind of cramped on those trucks and you may have a hard time finding a power plant that fits and isn't a B*tch to work on after instalation.
Can anyone tell me the axle ratio for the M62, or maybe there were several. The explanation of 1.5:1 vs 1.95:1 transfer-case ratios confused me a little. It's a 2-speed transfer-case, I think, so is one speed direct and the other either 1.5 or 1.95:1 reduction?
That truck is actually a "WC-62" not an "M62". The "M" designation for soft skins was introduced post war. Gear ratio in a stock WC axle was 5:83. There are 4:89 ring & pinion sets available from places like M series rebuild. The original war time 2sp T-case was the 1.5 to 1 ratio post was with the introduction of the M37 which used the same T-case BTW, was 1.98 to 1.
A 3.9(4 cylinder) Cummins might fit, but I don't think you will ever get a 5.9(6 cylinder) in there.....if a suitable Diesel engine comes along, like a 5.9 Cummins....
Also known as an NP200...close cousin to the well known NP205. I just gave a spare NP205 to a buddy that has some M37's and one 6x6. There is also a transfercase that is narrow and not a high-low like the NP200 that could be in some of those early Dodge trucks. My buddy had one of those too.The transfer cases in WC62's and 63's were essentially the same transfer case as in the M37 and M715. There are some WWII Dodges that still have the original 1.5:1 low range gears although most were changed over to the 1.98:1 during later Depot rebuilds. .
And this one time at Band Clamp..........Also known as an NP200...close cousin to the well known NP205. I just gave a spare NP205 to a buddy that has some M37's and one 6x6. There is also a transfercase that is narrow and not a high-low like the NP200 that could be in some of those early Dodge trucks. My buddy had one of those too.
Not sure of the 1/2 tons but I know the 3/4 ton WCs all came with a single speed transfer case (low range). That was a relativly small/flat T-case when compared with the 2 sp units used in the 1.5 ton & M37s.
Also, for the M37 guys (and I guess 715 guys), the stock emergency band clamp.![]()
