Transmission mount question
TGP (IL)
36
Metro East IL
If you use the NaPa site and enter Chevrolet K5 4WD Blazer it shows the same mount as your Auto Zone.
I can't remember if the mount is under the Trans. or T-Case on a Blazer.
All my Iron has the 205 T-Case and the mount is under the case which btw is the same mount as the bell housing mounts on a 4 speed manual 2wd truck.
I would suggest getting underneath your truck for a looksee.
Not that hard and then you can mentally compare with the picture.
TGP
jeepjseries
Fort Sill
TGP
Thanks for the help fellas but yet again the parts I'm looking for is non existent on my M1009. I discovered it buy putting it in four high and the front drive shaft is whats holding transmission and case up. It's called a transmission mount but is mounted under the transfer case.
TGP (IL)
36
Metro East IL
Actually I use CarQest or GM, but his link was available.
I don;t remember ever seeing a mount like that on a Chev 4x4 of any model,but again I'm kinda winging it on your K5 because I haven't been around one in many years,
Good Luck!
TGP
Warthog
244
OKC, OK
I use the napa website to look for an item and part number and then see which of the other stores have what I need.
Why not look in the Tech Manual parts manual, get the GM part number and then cross-reference it to NAPA, AutoZone, xyz, etc..............
TM 9-2320-289-34P, Figure 71, Item #2 and #4
Pluging these numbers into the www.napaonline.com and clicking the interchange button, shows the same numbers as listed above in the NAPA link.
Got to start thinking outside the box. :-D
Warthog
244
OKC, OK
Is this the proper mount? Duralast/Transmission Mount (2638) | 1985 Chevrolet Blazer 4WD 8 Cylinders C 6.2L Diesel | AutoZone.com
If not who knows what to tell them to look up to get the proper one. Not much luck around here with Napa. I use Autozone, Oriley's, and Advanced.
This is not the correct part.
Your truck is a hybrid so you will need to use two different models when ordering parts.
Tell them a:
1984 K5 Blazer with 6.2L and Turbo 400 tranny and NP208 transfer case - for everything except the engine and axles
or
1984 K30 Pickup with 6.2L J-code engine - for engine and axle parts (use this for the engine because the Blazer didn't come in a J-code version and your axles have been swapped)
Warthog
244
OKC, OK
There are two pieces to the mount. Two of each for a total of four. Post #6 shows the correct items. And the diagram in the TM 9-2320-289-34P shows how it goes together.
I was attempting to point you in the right direction and teach you how to start looking up the info yourself. That doesn't seem to be working yet.
So I will list all the part numbers for you.
1984 K30 Pickup, 6.2L J-Code Engine, TH400 transmission, NP208 transfer case.
Upper - GM 3705444
Lower - GM - 14009321
Upper - NAPA BK 6021034
Lower - NAPA BK 6021035
Upper - Autozone 2107 or A2107
Lower - Autozone 2108 or A2108
Upper - Oreilly's 2107
Lower - Oreilly's 2108
If your mounts are missing the hardware may be gone also, so you may need this kit.
Oreilly's - 3.1106G
List: AT Mount - 1984 Chevrolet K30 | O'Reilly Auto Parts
