  • Thread starter Deleted member 11142
  • Start date
TreadLite
20
Seattle, WA
Am I the only one that has trouble sleeping if I don't check out the site right before going to bed? Maybe I really am addicted? Perhaps this site is to us what facebook is to the masses.
5,161
In the future, could anyone that sees and error, please copy and paste the error to notepad. Then when you're back in this thread, copy and paste it back into here?
shenkmen
12
Lancaster, PA
Patracy,
Users need to view the source to see the error. How about removing the comment tags from around the errors so they will be in plain sight for everybody?
I sent the following to you via PM last night at 22:56. Did it make it through to you?
The DB Crapped Out
I'm guessing you caught this but in the case you didn't
Database error in vBulletin : mysql_connect() [<a href='function.mysql-connect'>function.mysql-connect</a>]: Too many connections /home/steelsol/test.steelsoldiers.com/includes/class_core.php on line 311 MySQL Error : Error Number : Request Date : Tuesday, November 29th 2011 @ 10:39:02 PM Error Date : Tuesday, November 29th 2011 @ 10:39:04 PM Script : http://www.steelsoldiers.com/conversations/78720-what-wheel-cylinder.html Referrer : Steel Soldiers IP Address : 173.188.80.238 Username : Classname : vB_Database MySQL Version :
5,161
Yes I got it. If everyone could post their errors like that, it would be great. I'm going to see if I can enable the php tag so we can retain formating.
5,161
PHP:
Database error in vBulletin :  mysql_connect() [<a   href='function.mysql-connect'>function.mysql-connect</a>]:   Too many connections   /home/steelsol/test.steelsoldiers.com/includes/class_core.php on line   311  MySQL Error   :  Error Number  :  Request Date  : Tuesday, November   29th 2011 @ 10:39:02 PM Error Date    : Tuesday, November 29th 2011 @   10:39:04 PM Script        : http://www.steelsoldiers.com/convers...-cylinder.html Referrer      : Steel Soldiers IP Address    : 173.188.80.238 Username      :  Classname     : vB_Database MySQL Version :
Ok, here's how to post things and retain formating without any smilies showing up. Before your text enter
PHP:
  Then after you're done to the same with a /PHP in the box at the end.  I'll see about placing a code button.
