Well, now that you mention those, this is my stripped DRASH trailer.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Don't know why that one didn't cross my mind with the original question, I suppose because I consider it more of an LMTV trailer than Humvee. I'll have to go measure how long/wide the deck is. I know it is 56" of clear space side-to-side between the inner wheel wells
The deck has a BIG hole at the front where a large piece of equipment (generator? Looks like it) sat before, and a smaller very lightly decked section between the wheel wells, both would need a suitable flooring to make them usable. Also that mid-deck cross frame is fixed. I intend to cut it and put holders and lock pins similar to the back top and two front top side ones. Those were missing when I got the trailer, but were easy to replace with 8' sections of 2" aluminium square tube.
Picture 4, recovering it up with the Tahoe, will give a good indication of size. The two small boxes on the sides have hinged lids, but both were very loose on mine, so I popped them off for the trip home.
Cheers
Edit -
deck is 166" long
82" wide, except between wheel wells, which is 56"
View attachment 918536 View attachment 918537 View attachment 918538 View attachment 918539
