Humvee Trailer 10-15 Foot Length
Hummer Guy
703
United States Louisiana
Is there any MV trailer for the humvee that has 10 - 12 feet in length of cargo space? From what I seen, the original most used trailer for the humvee has a cargo space a little under 8ft in length, I would like to find something that's slightly longer
M813rc
2,720
Near Austin, Texas
Gooseneck isn't it?
The two version I have are 5th wheel. Both were designed as shelter carriers for the Humvee, but I use my M1028A2 to pull them.
The third picture is the frame and 5th wheel for a Humvee, by the time the trailer came to me, that part was long gone! Picture 4 is from the internet showing a different 5th wheel setup.
These trailers are like hens teeth though, I've only seen two of each. There are other types, but I've not seen any of those in person.
Cheers
M813rc
2,720
Near Austin, Texas
Not the most attractive trailers ever built.
That is very true!
I got the smaller one from a guy in Indiana for pretty cheap, the big one came out of a farmer's field near Fort Hood, paid $200 for that one.
The "small" one now has an S788 on it, the bigger one I added Humvee fenders and a diamond plate deck to haul my M274 (Mule) on it. I took the big box off, it just wasn't useful there, and added a spare tire rack and the platform from an M1087. The tool box on the left fender isn't attached, I was just seeing how it looked.
Cheers
M813rc
2,720
Near Austin, Texas
Well, now that you mention those, this is my stripped DRASH trailer. ;)
Don't know why that one didn't cross my mind with the original question, I suppose because I consider it more of an LMTV trailer than Humvee. I'll have to go measure how long/wide the deck is. I know it is 56" of clear space side-to-side between the inner wheel wells
The deck has a BIG hole at the front where a large piece of equipment (generator? Looks like it) sat before, and a smaller very lightly decked section between the wheel wells, both would need a suitable flooring to the trailer usable. Also that mid-deck cross frame is fixed. I intend to cut it and put holders and lock pins similar to the back top and two front top side ones. Those side ones were missing when I got the trailer, but were easy to replace with 8' sections of 2" aluminium square tube.
Picture 4, recovering it up with the Tahoe, will give a good indication of size. The two small boxes on the sides have hinged lids, but both were very loose on mine, so I popped them off for the trip home.
Cheers
Edit -
deck is 166" long
82" wide, except between wheel wells, which is 56"
Coug
4,073
Olympia/WA
The deck has a BIG hole at the front where a large piece of equipment (generator? Looks like it) sat before, and a smaller very lightly decked section between the wheel wells, both would need a suitable flooring to make them usable. Also that mid-deck cross frame is fixed. I intend to cut it and put holders and lock pins similar to the back top and two front top side ones. Those were missing when I got the trailer, but were easy to replace with 8' sections of 2" aluminium square tube.
Cheers
Edit -
deck is 166" long
View attachment 918536 View attachment 918537 View attachment 918538 View attachment 918539
Typically they were an ECU at the front, and generator mounted between the fenders, though some other variants do exist.
I believe military rated these as 6k lb trailers when towed behind larger trucks, and 4200 if towed by the HMMWV. Until you get to the big trailer they rated for 12k, they all had the same axles, wheels, brakes, etc.
I towed one with a 35kw generator and 12 ton ECU for 3 years behind a 5 ton expando van (M934A2) in Korea. The longer wheel base made it MUCH easier to back up than the shorter versions.
I've been hoping to come across one of those for a few years now. I ended up with the shortest version, and put an MEP802 5kw generator onto it. Nice thing about the small version was the 55 gallon fuel tank built into it, where all the larger ones were about 20-30 gallon as day tanks.
awolhmv
Ca
