cucvrus
- 10,395
- 113
- Jonestown Pennsylvania
I hate to ask but does anyone know what spring shims are needed on the rear springs of a lifted M1009 that has a 23-degree driveshaft angle on the rear. Also, the front driveshaft is a stock size with a 19-degree angle. I fear if the vehicle were to bounce it would extend the front shaft past its limit and break the transfer case or the flange of the transmission. It appears fully extended. I never had to think this way before. Thank you in advance.
