SgtJay88
- 5
- 3
- Howard, OH
Well that narrows it down, good job. ACDelco, Valvoline, AMS Oil, Fram, Mobil or what?DEX VI
SAys right there in Lube Order
The brand makes absolutely no differenceWell that narrows it down, good job. ACDelco, Valvoline, AMS Oil, Fram, Mobil or what?
Ok thanks, that's all I needed! Just making sure I dont use something someone else learned not toThe brand makes absolutely no difference
Apparently DEX VI is backwards compatible with II and III, meaning you can use VI instead, but not the other way around. But I will keep using DEX III if I can find it.Did i read this right? Dexron VI instead of Dexron III?
