On 240 Volt single phase its 24Volt AC on both 1 and 3 terminals. I've ordered a new voltage regulator(the aftermarket one). I found that the adjustment screw on the potentiometer has been sheared off. Ill see what happens after the install then post what I find.Is the 24V on all legs or one?
Okay, the reason I asked was I have seen two times where if it is one leg, the wire broke inside the crimped connector insulation cover behind the output lugs. It is basically arcing in there & causing reduced VAC output. You won't ever notice it until it lights on fire or you remove the output panel and pull really hard on the wire. The insulation is stiff & holds the wire in place. I guess moisture sneaks in & corrodes it.On 240 Volt single phase its 24Volt AC on both 1 and 3 terminals. I've ordered a new voltage regulator(the aftermarket one). I found that the adjustment screw on the potentiometer has been sheared off. Ill see what happens after the install then post what I find.
