- 4,487
- 4,367
- 113
- Brentwood, Calif
Well, you Found the problem….Ok....
I don't see part 28, but...
#30 was inserted inversely directly into the screw #27 and the spring #29 into it.
Now I can't remove spring from TC, something is blocking inside.
Rotate the spring with some needle nose..also, have someone move the Tcase shifter back and forth lightly.
item 28 is on the plug, it’s a rubber o-ring
