Sagging door of doom
Jeepadict
780
Round Mountain, NV
I have never seen a cucv that the doors closed easy. My doors are lined up very well, I put new doors seals in as I rebuilt everything. Still have to close them hard. I will look at the youtube university to see what I can do.
New seals will do that if you don't adjust the striker to allow for the new material instead of the 40 year old rubber.
If you ever wanted a baseline refrence compare the door behavior with the original, then with no seal at all, then with a new seal. You should be able to adjust it to your preference with a better refrence.
Sent from my SM-G970U using Tapatalk
deank
501
Florida
Will adjusting the striker change the position of the door? Right now when I close the door, granted it is a hard close, the door is aligned all the way around.
WWRD99
1,825
York Pa
If you don't have the round piece of plastic around the striker you can make one out of half inch pex pipe. Slice the side and roll it on the striker. Will make closing the door very easy. I have done it on all mine.
Indyharleyguy
70
Carmel IN
I have the same problem. When I asked about it on here almost everyone said if the door bolt didn't have the plastic piece on it I need to replace them. I bought some on Amazon but waiting for a little warmer here in Indianapolis to actually do it.
I'm hoping it fixes my problem?
