VIC to Cellphone Adapter and Military Radio Digital Modes Adapter
Swiss Humvee M1123
REIDEN
All of the adapters are spoken for and all have shipped. Thanks everyone for participating.
Here are instructions for how to use them:
This adapter allows you to make calls and hear music, navigation, etc through your VIC-3 headset by connecting to your phone using Bluetooth. Your phone is treated as a "radio" by the VIC-3 system.
The adapter connects to one of the radio ports on the VIC-3 Master Control Station or Radio Interface Terminal using a CX-13473 or CX-13489 cable (supplied by you).
When you turn on the VIC-3 for the first time with the adapter connected you can use your phone to search for Bluetooth devices and connect to "VIC-3". Your phone will automatically reconnect from then on.
To hear audio from the phone, on your VIC-3 crew box you must set the "MONITOR" knob to "ALL" or to "RADIO X" where "X" is the letter of the port you have connected the Bluetooth adapter to.
To place a call, on your VIC-3 crew box you must set the "WORK" knob to "RADIO X" where "X" is the letter of the port you have connected the Bluetooth adapter to. Dial a call on the phone as normal and hold the PTT on your VIC-3 headset to talk to the person on the other end.
The VIC-3 Master Control Station program settings must be set so that the crew box you are using has permissions to the appropriate radio port. If in doubt, set the MCS power switch to "ALL" and all crew boxes will have full permissions. You can also get fancy and make a program to disallow specific crew boxes from talking to or hearing from "RADIO X", so they can't participate phone calls.
VIC-3 Lite MCS's have no programs and default to "All".
Augi
Guten Tag
Verkaufen Sie diese Adappter?
Weil ich möchte auch ein VIC 3 kaufen und dann mein CB Funkgerät darüber verbinden geht das?
Merci
Liebe Grüsse aus der Schweiz
Matthias
Swiss Humvee M1123
REIDEN
The new run of boxes is complete. I'll send messages to everyone who as expressed interest with information on what to do next.
Thanks for all of your support!
Augi
Guten Tag
Haben Sie noch so eine Box für das VIC 3 ?
Kann ich dann über diese Box auch ein CB Funkgerät verbinden?
Danke
Matthias
