Military Air Compressors - All Sorts and Sizes
20,545
OPERATOR’S, UNIT, AND INTERMEDIATE DIRECT SUPPORT MAINTENANCE MANUAL
COMPRESSOR UNIT, RECIPROCATING 15 CFM, 175 PSI, GASOLINE ENGINE DRIVEN
MODEL 10GT8G
(NSN 4310-01-247-2584)
20,545
ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE
REPAIR PARTS MANUAL, COMPRESSOR, RECIPROCATING, GASOLINE ENGINE DRIVEN,
15 CFM, 175 PSI, MODEL 50-6840
(NSN 4310-01-164-5544)
20,545
OPERATOR’S, ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL
COMPRESSOR, RECIPROCATING: AIR, TANK MOUNTED, GASOLINE ENGINE DRIVEN, 15 CFM, 175 PSI
MODEL C=20X-80/6E
NSN 4310-01-1 28-1 826
20,545
OPERATOR, UNIT, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL LUBRICATION AND SERVICING UNIT, POWER OPERATED, TRAILER MOUNTED, 15 CFM COMPRESSOR
MODEL LST-178A-85
(NSN 4930-01-230-0781)
20,545
OPERATOR AND ORGANIZATIONAL MAINTENANCE MANUAL LUBRICATING AND SERVICING UNIT, POWER OPERATED, TRAILER MOUNTED, 23 CFM COMPRESSOR, RECIPROCATING, GASOLINE DRIVEN
(HENRY SPEN MODEL 901765-1)
FSN 4930-017-9167
20,545
OPERATOR'S, ORGANIZATIONAL, DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE MANUAL FOR
COMPRESSOR, ROTARY, AIR, DED, 250 CFM, 100 PSI TRAILER-MOUNTED
NSN 4310-01-158-3262
COMPONENT OF PNEUMATIC TOOL AND COMPRESSOR OUTFIT
NSN 3820-01-195-4167
INGERSOLL-RAND MODEL NUMBER P-250-WDM-H268
20,545
OPERATOR’S, UNIT, DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE MANUAL FOR
COMPRESSOR, AIR: ROTARY SCREW, 750 CFM, 100 PSI , WHEEL-MOUNTED, DED
SULLAIR MODEL 750 DP
(NSN 4310-01-053-3891)
20,545
Assorted other compressor materials...
Lube Order -
COMPRESSOR, ROTARY, AIR; DIESEL ENGINE
DRIVEN, 250 CFM, 100 PSI; TRAILER MTD; TWO
WHEEL (DAVEY MODEL 14M250RPV)
(NSN 4310-00-256-9319)
Lube Order -
TRAILER MOUNTED
TM 5-4310-371-14
OPERATOR'S, ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL COMPRESSOR UNIT, RECIPROCATING ELECTRIC 25 CFM, 175 PSI
NSN 4310-01-090-5911
TM 10-4310-392-13&P
OPERATOR'S, UNIT AND DIRECT SUPPORT MAINTENANCE MANUAL
(INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST)
FOR ATLAS COPCO RECIPROCATING COMPRESSOR
(No NSN)
20,545
TB 43-0151 Inspection & Testing of Air & Other Gas Compressors
Special Thanks to @Guyfang for finding and posting this!
20,545
Air Compressor Model 20-905
TM-5-4310-367-14
COMPRESSOR, RECIPROCATING: Air, Handtruck Mounted, Gasoline Engine Driven, 8 cfm, 175 psi
Special Thanks to @glassk for finding and posting this TM!
