Military Air Compressors - All Sorts and Sizes
20,748
OPERATOR’S, UNIT, AND INTERMEDIATE DIRECT SUPPORT MAINTENANCE MANUAL
COMPRESSOR UNIT, RECIPROCATING 15 CFM, 175 PSI, GASOLINE ENGINE DRIVEN
MODEL 10GT8G
(NSN 4310-01-247-2584)
20,748
ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE
REPAIR PARTS MANUAL, COMPRESSOR, RECIPROCATING, GASOLINE ENGINE DRIVEN,
15 CFM, 175 PSI, MODEL 50-6840
(NSN 4310-01-164-5544)
20,748
OPERATOR’S, ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL
COMPRESSOR, RECIPROCATING: AIR, TANK MOUNTED, GASOLINE ENGINE DRIVEN, 15 CFM, 175 PSI
MODEL C=20X-80/6E
NSN 4310-01-1 28-1 826
20,748
OPERATOR, UNIT, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL LUBRICATION AND SERVICING UNIT, POWER OPERATED, TRAILER MOUNTED, 15 CFM COMPRESSOR
MODEL LST-178A-85
(NSN 4930-01-230-0781)
20,748
OPERATOR AND ORGANIZATIONAL MAINTENANCE MANUAL LUBRICATING AND SERVICING UNIT, POWER OPERATED, TRAILER MOUNTED, 23 CFM COMPRESSOR, RECIPROCATING, GASOLINE DRIVEN
(HENRY SPEN MODEL 901765-1)
FSN 4930-017-9167
20,748
OPERATOR'S, ORGANIZATIONAL, DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE MANUAL FOR
COMPRESSOR, ROTARY, AIR, DED, 250 CFM, 100 PSI TRAILER-MOUNTED
NSN 4310-01-158-3262
COMPONENT OF PNEUMATIC TOOL AND COMPRESSOR OUTFIT
NSN 3820-01-195-4167
INGERSOLL-RAND MODEL NUMBER P-250-WDM-H268
20,748
OPERATOR’S, UNIT, DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE MANUAL FOR
COMPRESSOR, AIR: ROTARY SCREW, 750 CFM, 100 PSI , WHEEL-MOUNTED, DED
SULLAIR MODEL 750 DP
(NSN 4310-01-053-3891)
20,748
Assorted other compressor materials...
Lube Order -
COMPRESSOR, ROTARY, AIR; DIESEL ENGINE
DRIVEN, 250 CFM, 100 PSI; TRAILER MTD; TWO
WHEEL (DAVEY MODEL 14M250RPV)
(NSN 4310-00-256-9319)
Lube Order -
TRAILER MOUNTED
TM 5-4310-371-14
OPERATOR'S, ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL COMPRESSOR UNIT, RECIPROCATING ELECTRIC 25 CFM, 175 PSI
NSN 4310-01-090-5911
TM 10-4310-392-13&P
OPERATOR'S, UNIT AND DIRECT SUPPORT MAINTENANCE MANUAL
(INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST)
FOR ATLAS COPCO RECIPROCATING COMPRESSOR
(No NSN)
20,748
TB 43-0151 Inspection & Testing of Air & Other Gas Compressors
Special Thanks to @Guyfang for finding and posting this!
20,748
Air Compressor Model 20-905
TM-5-4310-367-14
COMPRESSOR, RECIPROCATING: Air, Handtruck Mounted, Gasoline Engine Driven, 8 cfm, 175 psi
Special Thanks to @glassk for finding and posting this TM!
Guyfang
27,124
Burgkunstadt, Germany
LO 5-4930-217-12 dated 1978
LUBRICATION ORDER FOR LUBRICATING AND SERVICING UNIT: POWER OPERATED; TRAILER MOUNTED, 23 CFM COMPRESSOR, RECIPROCATING GASOLINE DRIVEN (ELLIOTT MACHINE MODEL ENG-3) FSN 930-935-4451
TM 5-4930-217-14 dated 1968 wc#5
OPERATOR, ORGANIZATIONAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL, LUBRICATING AND SERVICING UNIT: POWER OPERATED; TRAILER MOUNTED, 23 CFM COMPRESSOR, RECIPROCATING GASOLINE DRIVEN (ELLIOTT MACHINE MODEL ENG-3) FSN 4930-935-4451
TM 5-4930-217-20P 1990 wc#3
TECHNICAL MANUAL; ORGANIZATIONAL MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST FOR
LUBRICATING AND SERVICING UNIT, POWER OPERATED, TRAILER MOUNTED, 23 CFM, COMPRESSOR, RECIPROCATING, GED (ELLIOTT MACHINE MODEL ENG 3) NSN 4930-00-935-4451
TM 5-4930-217-34P dated 1990 wc#2
TECHNICAL MANUAL, DIRECT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST FOR LUBRICATING AND SERVICING UNIT, POWER OPERATED, TRAILER MOUNTED, 23 CFM, COMPRESSOR, RECIPROCATING, GED (ELLIOTT MACHINE MODEL ENG 3) NSN 4930-00-935-4451
