M939 series 5 ton capacities
JasperM925A2
12
Washington
I checked my 1996 version of the –10 and the on-highway weights (page 1-9) and the key verbiage on the description and data sheet (1-18)we are looking for have already been omitted. I would think the pre CTIS 1984 version should still have them, let me know if you find those pages I will gladly go in on some of the cost for a good clean copy or printable version of the first handful of pages from the TM.
Yeah I'm pretty good at finding things on the Internet if they exist out there for free, I have the 96, 04, and 2012 versions of the 272-10. If no one has a pdf of the 1984 version I think I'll just buy it and see if I can find a place to scan it to a pdf and just share it here. I did reach out to AM General to see if they might have any specs for the actual max rated capacities of the truck but not holding my breath. I do have a couple other PDFs for the haldex abs, the brakes/wheel bearing maint. for the gttu202-30-20 trailer, and a couple other odd ball t.m.s I don't think I saw when I was digging around on here I would be willing to share.
20,499
If you come across any hard copy manuals, don't hesitate to send them to me. I run a printshop and we regularly "scan to pdf" and add the OCR part of the job as well. Only thing it will cost you is to send it by Media Mail (cheapest way to send anything!) and I will return the book with the spine cut off and re-glued.
JasperM925A2
12
Washington
Unfortunate update...
The website is now updating their page to reflect that they only have the 2004 version of the -10
I'll try pestering AM General again.
JasperM925A2
12
Washington
Let me look in the library at the Museum. @Mullaney , @JasperM925A2 , what page range is needed? If the TM is there, it will be loose leaf, I can scan to PDF and send it off to the TM section.
Unfortunately don't have a page range, it should be near the front of the manual, Weights Table 1-2 should have two separate columns one showing highway weight capacities including towed weight allowed and the other showing cross country. Just looking for enough of the manual to satisfy dot in the instance someone is pulled over while towing.
JasperM925A2
12
Washington
I just ordered 1984 version, but it has changes 1-4, and a little beat up. I will update when I get eyes on.
Hopefully it wasn't the same place I just tried ordering the 1984 version from. Portrayal Press shows they have one but only have 2004 version in stock.
Fingers crossed !!
Jbulach
2,343
Sunman Indiana
Fingers crossed !!
Not from Portrayal. Also, just found another possibility. PM sent to give you a chance at it before I post up to the public.
