MEP026C 28 volts 109 amps good for what?
NDT
7,348
Camp Wood/LC, TX
I ran across one of these. OK I know it's gas and loud. Is this usable for some kind of solar battery bank backup recharge generator or power outage generator used with batteries and a 24-120 inverter? I think the 4 cyl mil std gas engine can be converted to natural gas.
NDT
7,348
Camp Wood/LC, TX
Yes it does. I will pick it up tomorrow and get some pictures. It turns over and is all there, that’s all I know at this point.
Guyfang
26,785
Burgkunstadt, Germany
Thats good. Because without the solid state ignition, the reliability of the engine is much reduced. I hated this engine before the upgrade. Next is the fuel pump. These engines are old, so keep an eye on the oil level. The diaphragm in the fuel pump can crack/split. Then fuel runs down into the oil pan. Doesn't take long and the oil/gas will erupt out of the oil filler tube. But if you go to NG, then you can forget that problem. Other than that, this is a sweet little engine!
NDT
7,348
Camp Wood/LC, TX
Update: I did acquire the unit last week. Its a bit weathered so I disassembled it for paint. Today a goodie box arrived from Eastern with all the parts to bring her back to life. Eastern was able to acquire the inventory from Saturn Surplus, who was the go-to supplier for these generator parts for as long as I can remember.
