Brad
- 112
- 43
- Bolivar, Pa
HAd a thread going on fuel pump and carburator, but am still having trouble. Spent some time today trying to find out what could be wrong?
My Son's M135 will start right up, and seems to idle fime. I was thinking fuel all along, but then maybe condenser? Would run down the road just great, then shut off, but then start right back up and run fine for a while? Then shut off again.??
So here is what I did today. It started up and I was feeding it gas, just above idle. It strted to sputter and miss, and shut off. I was giving it enough gas that would seem to be the same as if cruising on level road at medium speed. It would then start right back up, and after a couple minutes playing with the throttle I could get it to stall again.
Then I noticed something. After it stalled, I could not hear the fuel pump running. If I shut everything down and turned the power back on the pump would run. But after it would stall, no pump running. However once after a few minutes, the pump just came back on by itself. I had not shut the ignition or power switch off.
Does the fuel pump shut itself down if there is enough fuel un the float of the carb?
Also, I took the top off the carb and the float area was full of fuel?
I have a couple sets of points and condensers ordered, and am going to order a set of plugs, But I am really perplexed???
Thanks for any help in advance
