squarebodybo
- 0
- 1
- Indiana
Looking for some help. I have an m1009 i purchased and i am having trouble timing it. I put on new injectors, timing chain, electric fuel pump, and have two IP I've both tried with same result. IP alignment pin is in correct oval hole on gear.
My issue is my load advance lever does very little if anything and I get black smoke if I press the pedal down. If i adjust full retarded or full advance my lever does nothing.
With both pumps. It idles great with no smoke at whatvi feel is best timing location. 1/16 retarded from line. If I fully retard or advance I do get excessive white smoke from crank. To add, my electric pump is showing 3.5-4 psi. The 6.2 should have around 5.5 to 8.
Any ideas on how to fix this? Is it bc my new TC and gear seat is tight and new? Would it be my low psi from pump? Should I screw in the adjustment screw on advance lever? I just don't know why my advance lever doesn't work on both of my pumps at any location I place IP. Advance lever worked before all of the work i did. My injectors were in bad shape and my original timing chain was way out of spec.
